JJKim
Sep 01, 2019Aspirant
Orbi Satellite will not reset - no flashing amber light
One of my satellites stopped working suddenly. I've tried to reset multiple times - including holding it down for over a minute - but the power light does not flash nor is there any light at all coming from the top. Any suggestions would be appreciated.
So unplug the RBS from the power for 30 seconds, Then plug back in. press the reset button for 15 seconds only. Then let go. Does the top ring LED start to blink?
If not, I recommend the RBS be replaced.
Oh, geez. So, the power LED is green (not "nothing"), you can hear or feel the "click" when the paperclip goes into the tiny "Reset" hole, but the power LED never changes?
If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
Press paperclip in reset hole for 30 seconds
Keep pressing paperclip while removing power
Keep pressing paperclip for another 30 seconds while apply power- JJKimAspirantThanks CrimpOn for the advice. I was on the phone earlier with technical support and they had me do the same thing. Power light never changed so they're going to replace the satellite.
You got them on the PHONE? Wow! My 90 days ran out two years ago (warranty, too). If mine breaks, it's back to Costco I go.
