GaryInEdmond
Dec 05, 2016Guide
Orbi satellite will not show connected devices
When I connect to my orbi satellite via 192.168.1.5, I get the normal home screen. When I click on connected devices, I get the "please wait a moment screen" and the devices never show. This starte...
- Jun 07, 2017
Hello tsutaz
Find the Ip address of those satellites in the attached devices then put that ip address into your web browser should be a 192.168.1.x address then you can see what is attached to that satellite.
DarrenM
Fullmoon815
Dec 06, 2016Aspirant
I have the same issue. I attached a new computer to the Orbi satellite via wired connection. The connection is solid but the Attached Device screen did not register this device at all. Another issue is that some devices shown has two IP addresses. Is there a stealth mode?
- Fullmoon815Dec 10, 2016Aspirant
After update the Satelitte firmaware to V1.4.0.16, it fixed my problems, no more duplicate IP address, nor stealth attached device.
- aguaschJan 07, 2017Guide
I experience this problem on both the .16 and .34 firmware. I connect directly to the ORBI Sat and the main screen shows devices are connected. However, when I click on "Connected Devices" it spins and does not display any data. I have tried on EDGE, IE11 and Chrome so it is not a browser problem.
This is a good product and it is a shame that Netgear does not do a better job of cleaning up their software. I also wish they would fix the Genie App to work properly with the ORBI.
- GaryInEdmondJan 07, 2017Guide
I experienced the problem with multiple browsers in previous versions, however, the problem went away in version .34.
