GaryInEdmond
Dec 05, 2016Guide
Orbi satellite will not show connected devices
When I connect to my orbi satellite via 192.168.1.5, I get the normal home screen. When I click on connected devices, I get the "please wait a moment screen" and the devices never show. This starte...
- Jun 07, 2017
Hello tsutaz
Find the Ip address of those satellites in the attached devices then put that ip address into your web browser should be a 192.168.1.x address then you can see what is attached to that satellite.
DarrenM
PoolBall
Jun 01, 2017Guide
Go to the IP address of your satellite. Login with same credentials as your Orbi Router
RIGHT click on "Connected Devices"
Select "Open Link in New Tab" (or) "Open Link in New Window"
New Tab or Window will show the information
If you go back to the satellite screen and left click on Connected Devices, it will work until you end your session.
Bing-Stroller
Jun 01, 2017Luminary
I have just tried to establish what devices are connected to my satellite.
Have got the IP from the router Attached Devices.
I log in to the satellite IP with the router sign in details no problem,
I get the Orbi logo and colours but it displays a message "Please wait a moment..." but it never resolves.
Have been on V1.10.1.2 since the auto update and have used this page since that update but now it will not display.
- peteytestingJun 01, 2017Hero
try clearing yoour browser cache
- Bing-StrollerJun 01, 2017Luminary
Thanks, tried that - made no difference.
- tsutazJun 03, 2017GuideI just installed an additional satellite ( RBS50 ). Firmware shows v1.10.1.2. This is my 2nd satellite. It's installed upstairs and trying to fill so low coverage spots upstairs. I've rebooted an imac and a sony playstation upstairs. I can't tell if they are on the new satellite?
