Blair2201's avatar
Apr 05, 2020
Orbi Satellite wired but significantly slower than main router
I recently installed an office pod in the back garden and ran a Cat 6 cable from the main switch (connected to RBR40) out to the pod (about 30 mtrs).  The cat 6 is then hard wired to a RBS40.    When I run a wifi test speed near the main router I'm getting around 300mbps, however, when I run the same test in the pod I get 94 mbps.  The connection frequency is 5Ghz.
I would welcome any suggestions to fix this, it's driving me mad!
  • FURRYe38's avatar
    Be sure to disable then re-enable the wifi radio on your mobile device before testing speeds at the RBS. Helps to ensure the device connected at the RBS and not the RBR.
    • Blair2201's avatar
      Blair2201
      Tutor
      Thank you Furry for your advice, I'll check your proposed settings out tomorrow and report back.
      Interesting though, I checked the wired speed on my PC in the pod, that was only getting 94mbps, so my satellite router's performance is significantly reduced by the speed coming through the wired connection.
      Now I'm struggling to understand why the switch that the pod is connected to delivers 300mbps to my PC but only 30mtrs of cable drops that to a 3rd of the speed?  But that would explain the wifi speed from the RBS.
      Any ideas?
      • FURRYe38's avatar
        Please give some feed back to the questions presented.
        Any ideas?
