BPearce
Aug 16, 2019Guide
Orbi Satellite wired shows wireless
Been reading previous discussions (some from over a year ago) regarding these issues with wired satellites and am disappointed to be having this problem still. Followed the "procedures" for starting ...
Aug 16, 2019Guru - Experienced User
What FW version is currently loaded on the Orbi system?
There are some known issues with switches with Green Ethernet features. I see the 1016D has Energy Effiecient features:https://us.dlink.com/en/products/dgs-1016d-16-port-gigabit-unmanaged-desktop-switch
To test this out, directly connect the RBS to the back of the RBR and see if the status changes to wired connection. If it does, then the switch maybe a factor.
Can the EE feature on the switch be disabled by chance?
Orbi RBS do worth with wired connections and with switchs, it's some of these switch features that can cause problems.
- BPearceAug 16, 2019GuideI have loaded the latest firmware. Yes I have read about the issues with some switches but am not interested in bypassing or fiddling with its “features” when it works fine with the Luma wifi I normally use (and according to others in these forums with other WiFi mesh systems).
Clearly an issue with orbi that Netgear needs to address instead of requiring work arounds that are unnecessary with its competitors products.- FURRYe38Aug 17, 2019Guru - Experienced User
Orib works with non managed and non green ethernet switches.
Good luck then.
- BPearceAug 17, 2019Guide
Appreciate the help and input, you were the only one to respond. Unfortunately I don't find it acceptable that NETGEAR would not have their product work in the same environment other products work. Who wants to turnaround and buy another hub or switch after shelling out the amount of money we do for this product.
it works for now, will let them know about the ridiculous start up procedure if power goes out or firmware is updated. Will not recommend to anyone else to buy these
