DNufer's avatar
DNufer
Tutor
Apr 14, 2021
Orbi Satellite with non-Orbi Router
Can an Orbi satellite be hooked up with a Netgear router?
The Satellite is: Netgear Orbi Satellite RBS20 for indoor use only
The Router is: Netgear AC1900 Cable Modem Voice Router, Model: C7100V
I was trying and they weren't connecting.  It would be good to know if it's even doable before I try more...
Thanks!
  • The router is hooked up and working fine.  I just want to be able to add the satellite to it, if it's compatible.
  • plemans's avatar
    No. it won't work.
    The only satellites that work without an orbi router are the RBS40V and the RBS50Y as they have an extender mode.
    • DNufer's avatar
      DNufer
      Tutor
      Bummer!  But, thanks for letting me know.  Saves me a lot of wasted time and grief.
