pmjoen
May 09, 2019Aspirant
Orbi Satellite won't connect after power outage
Every time the power goes out, the satellite wont reconnect with base. I have even plugged it in next to the router (litterally 1 inch away) still wont sync. Then after a few days of trying to rest...
ghostdog1
May 10, 2019Aspirant
I'm having a similar issue and have done the full factory reset but it only lasts for a short period of time (maybe a day or two). I'm starting to wonder if power outages fried something.
May 10, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Is Beamforming, WMM and Daisy chain enabled or disabled?
