TheJ2017
Aug 01, 2017Aspirant
Orbi Satellite Won't Connect (Despite Blue Ring)
I have not had any issues with my orbi router / satellite until just recently (possibly the newest firmware via autoupdate?) My router and satellite have always been in the same places and have worke...
YabbadabbaDoooo
Aug 01, 2017Apprentice
What FW version are you running? Netgear just released 1.12.0.20 since they acknowledged 1.12.0.18 had a bug in it. What you are describing sounds very much like a FW issue and many others have experienced similar issues. Unfortunately, you may have to do a Factory Reset depending on what FW version you are on. I have the RBK40 AC2200 system and 1.11.0.20 has been the only FW my system has run smoothly on. If you post a little more info I will see if I can help.
- TheJ2017Aug 01, 2017Aspirant
It was 1.12.0.18, but i found out the satellite never upgraded and was still a lower firmware. I just guessed my satellite's login (since i couldn't see the 192.168.1.x number of the satellite since it wasn't connected. I upgraded the firmware to 1.12.0.18 and now it works. Thanks for offering to help!
- Nyfireman3097Aug 19, 2017AspirantI'm having the same issue. I am not tech savvy. And chance of helping me through it ?
- Retired_MemberAug 22, 2017
These are some steps you can follow on your end.
1. Power-cycle the satellite(unplug it, wait for 10-15 seconds, and plug it back). After this the satellite will automactically try to connect with the router. If the ring led on satellite turns blue, check under connected satellites on router GUI, if you can see the satellite or not.
2. If not, reset the satellite for 30 seconds. Follow the same steps as above.
