Hawk600's avatar
Nov 10, 2018
Orbi Satellite won't downgrade
Does anybody knows what is going on with my RBS50?  This new firmware 2.2.1.210 is bad and keeps dropping the connection with the router.
I tried to manually downgrade the firmware and after starting the process it says is loading and completes at 100% with no error but after it reboots it still in the latest firmware 2.2.1.210, done it 5 times same result....
  • FURRYe38's avatar
    Try a different browser, IE11, FF or Opera. Do a factory reset on the satellite. Hold in the reset button until the top LED turns on AMBER then let go.
    • Hawk600's avatar
      Hawk600
      Star
      Thank you FURRYe38, I tried all your suggestions, none worked!
      I am not sure what is going on since I downgraded the firmware on this satellite before without issues. I am just wondering if NG is either locking downgrades now or the version I am trying to upload is too old, tried 2.0.0.74 and 2.0.1.4.
      The process works fine and I see the upload process screen complete @ 100%, than it times out and when it is back the current firmware still there!
      • FURRYe38's avatar
        Well maybe it's not necesary to downgrade the satellite.
