Jwc065
Dec 11, 2020Follower
ORBI satellite worked finefor 6 months and now no power
it was working fine and then it turned off and won't start back up. I reset like troubleshooting said. I tried moving the satellite. I rebooted everything. I don't want to buy a new satellite or pay ...
michaelkenward
Dec 12, 2020Guru - Experienced User
Your subject says "no power". Does that mean what is says? The power doesn't get to the satellite? Or is it some other symptom? You can't reset something when it doesn't get power.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
