RGK30
Apr 17, 2022Follower
Orbi Satellite
I had an Orbi Satellite die and I want to remove it from my Orbi App Map. Is there a way to do this?
You can log in through the browser and under that attached devices page, click on "disconnect" by it.
- KevinLiTNETGEAR Moderator
Hi RGK30,
I understand that you have an Orbi satellite that is no longer in use and you would like to remove it from your Orbi App Map.
I have included steps below that will assist you in removing your Orbi satellite from your App Map:
- Launch the Orbi app.
- Navigate to the app Device Manager tile.
- Select an offline device.
- Tap Delete This Device.
Please let me know if this helps!!
Best,
Kevin
Community Team
