Jhawker82
Dec 07, 2019Aspirant
Orbi Satellites are not updating DNS
Having a bit of an issue with my satellites not updating DNS. When I initially setup my Orbis I was using the DNS servers in my lab. I have since torn down the lab and updated the DNS on my RBR20 to ...
ekhalil
Dec 07, 2019Master
Jhawker82 wrote:....... I have followed the instructions for factory resetting the entire system and rebuilding from scratch, but the resolv.conf is still pointing to the old DNS servers. ......
It seems that you have only factory reset the Orbi Router but not the Satellite, right?
How did you do the factory reset for the Satellite? Have you used a paper clip on the Satellite to reset it?
Jhawker82
Yes I have performed the paperclip reset multiple times on both the router and satellites. Insert paperclip in the reset hold until the light blinks amber. In fact I just did it again to no avail.
