walkerx
Feb 24, 2019Guide
Orbi Satellites connection
I have my orbi satellites connected via ethernet, yet one always wants to connect wirelessly.
will there be a reason why it wants to connect wirelessly even though it should be connecting via e...
- Feb 24, 2019
I've already contacted amazon and they are sending out a replacement system
ekhalil
Feb 24, 2019Master
Reasons can be one of the following:
- Bad connectivity caused by bad cable or switch in between
- You have a device or devices connected to the Satellite's LAN that causes loops on the Satellite and will cause Orbi to disable the LAN ports. Please check if you have such devices that can have both Ethernet and wifi connections.
- Becaue of a bug in current software (2.2.1.210) the loops can also be cause by enabling Daisy Chain while having Ethernet backhaul. Please make sure that Daisy Chain is disabled when you have Ethernet backhaul.
- walkerxFeb 24, 2019Guide
1) Tested in the spot where the other satellite (Sat2) is and get the same under the main orbi it shows that its (Sat1) connected via 5Ghz and backhaul is good, place my other satellite(Sat2) back in position and its connected via ethernet and backhaul is good. If I then place Sat2 where Sat1 is usually situated it is connected via ethernet and backhaul is good. This now makes me wonder if there is a fault with Sat1.
2) The only connection on the satellites is the cable for the backhaul
3) Checked the Daisy Chain setting on main Orbi and this is unticked
I have my Orbi's set outside of the DHCP range with their IP's reserved for all 3 units. But I have also noticed recently that if I disconnect the wan of my router (not the Orbi) my wifi goes down, which is also odd, as should still be able to access devices on my internal network
- ekhalilFeb 24, 2019Master
walkerx wrote:1) Tested in the spot where the other satellite (Sat2) is and get the same under the main orbi it shows that its (Sat1) connected via 5Ghz and backhaul is good, place my other satellite(Sat2) back in position and its connected via ethernet and backhaul is good. If I then place Sat2 where Sat1 is usually situated it is connected via ethernet and backhaul is good. This now makes me wonder if there is a fault with Sat1.
There can be an issue with your Sat1.
- Have you tried to factory reset the Satellite?
- Have you tried to connect the Ethernet backhaul to another LAN port on the Satellite?
walkerx wrote:...........
The IP address reservation should be from within the Orbi DHCP range NOT outside!
If you get wifi issues when you disconnect the WAN port this tells that your ISP router has also control over routing in your network or is also proving DHCP addressing. Do you have Orbi in Router Mode? If yes is your ISP router bridged? What is the model of your ISP router?
ekhalil wrote:
walkerx wrote:
.........I have my Orbi's set outside of the DHCP range with their IP's reserved for all 3 units. But I have also noticed recently that if I disconnect the wan of my router (not the Orbi) my wifi goes down, which is also odd, as should still be able to access devices on my internal network
The IP address reservation should be from within the DHCP range NOT outside!
That depends on router and operating systems, ip reservations can be done outside of the DHCP range
My Orbi is in AP mode and my router (Opnsense) controls the DHCPv4/v6 not the Orbi.
My setup is HG612 (modem) - Opnsense (router) - Orbi (wifi)
