walkerx
Feb 24, 2019Guide
Orbi Satellites connection
I have my orbi satellites connected via ethernet, yet one always wants to connect wirelessly.
will there be a reason why it wants to connect wirelessly even though it should be connecting via e...
- Feb 24, 2019
I've already contacted amazon and they are sending out a replacement system
Feb 24, 2019Guru - Experienced User
Probably need to get the system RMAd then. Also having it not show as working in the app, probably is a indication that the satellite is bad as your can't seem to get the app to work right with it in your other thread.
Good Luck.
- walkerxFeb 24, 2019Guide
- FURRYe38Feb 25, 2019Guru - Experienced User
The new system should be good. Keep us posted.
- walkerxFeb 25, 2019GuideHopefully it will be.
I even done a full reset of the whole system and definitely something wrong as in app it shows the satellite with incorrect 192.168.1.xx ip when I'm not even using that range and that satellite is on correct range.
Even under AP mode it was showing 192.168.1.254 as the DHCP server even though that is incorrect and it was selecting the correct ip, dns and gateway from my router. Took a couple of resets to get it to pick up the correct info throughout.
So fingers crossed that replacement works when it arrives.
