walkerx
Feb 24, 2019Guide
Orbi Satellites connection
I have my orbi satellites connected via ethernet, yet one always wants to connect wirelessly.
will there be a reason why it wants to connect wirelessly even though it should be connecting via e...
- Feb 24, 2019
I've already contacted amazon and they are sending out a replacement system
walkerx
Feb 24, 2019Guide
Feb 25, 2019Guru - Experienced User
The new system should be good. Keep us posted.
- walkerxFeb 25, 2019GuideHopefully it will be.
I even done a full reset of the whole system and definitely something wrong as in app it shows the satellite with incorrect 192.168.1.xx ip when I'm not even using that range and that satellite is on correct range.
Even under AP mode it was showing 192.168.1.254 as the DHCP server even though that is incorrect and it was selecting the correct ip, dns and gateway from my router. Took a couple of resets to get it to pick up the correct info throughout.
So fingers crossed that replacement works when it arrives.- FURRYe38Feb 25, 2019Guru - Experienced User
Should be. :smileywink:
- walkerxMar 05, 2019Guide
new system installed, but noticed after moving satellites to their new locations and rebooting the main orbi, it can take up to 10 minutes for the satellite to connect wirelessly (its about 25 feet away).
Also noticed that in the web interface it randomly reports the device as disconnected
