walkerx
Feb 24, 2019Guide
Orbi Satellites connection
I have my orbi satellites connected via ethernet, yet one always wants to connect wirelessly.
will there be a reason why it wants to connect wirelessly even though it should be connecting via e...
- Feb 25, 2019
I've already contacted amazon and they are sending out a replacement system
Mar 05, 2019Guru - Experienced User
25feet maybe too close, try 30feet.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
walkerx
Mar 05, 2019Guide
Try enabling Beamforming and MIMO.Try disabling the following and see:
30ft is in the garden, so no can do
on channel 13
both enabled
20/40 not really best idea setting to 40 in an area with a lot of 2.4ghz wifi connections being broadcast
daisy chain is disabled
fast roaming enabled so it can connect to the satellites quicker
ipv6 settings not available in ap mode
- FURRYe38Mar 05, 2019Guru - Experienced User
Try settin the power output levels from 100% to 75% or 50% and see if this changes anything.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).30ft is in the garden, so no can do
on channel 13
both enabled
