Datoeter
Feb 25, 2020Aspirant
Orbi satellites do not connect anymore
Hi All, Till yesterday my Orbi's worked fine, i have two indoor satellites and one outdoor satellite. Now i seems that the router cannot connect with the satellites. I tried rebooting, manual syn...
- Mar 04, 2020
Hi all,
I returnened the Orbi set and got a new set. The old set was faulty. I connected the new set, there were no problems.
Thank you all for your help.
Feb 25, 2020Guru - Experienced User
Try a factory reset on the RBR and ALL RBS. Bring the RBS near the RBR and try to add them, 1 at a time. 6-10feet.
Let us know if this works, if so, then place the RBS back in there remote locations.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Retired_MemberFeb 25, 2020
FURRYe38 wrote:Try a factory reset on the RBR and ALL RBS. Bring the RBS near the RBR and try to add them, 1 at a time. 6-10feet.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).any comment on the FW numbers??
- FURRYe38Feb 25, 2020Guru - Experienced User
RBSY FW version will differ from RBR/RBS. Depending upon the mode. Most recent version doesn't match up with RBR/RBS. Doesn't seem to keep in line with RBR/RBS versions. Just as long as the RBSY is using the latest version available.
RBR/RBS has v2.5.1.8 for manual update if they choose to manually update here.
That's right...the OP has the OUTDOOR device. :smileyhappy:
- DatoeterFeb 25, 2020Aspirant
Hi,
Thank you for you're response. I will try it now.The factory reset, where can i find that option? Or is it the little hole in the back of eache device?
Yes, press the reset button on each device for 15 seconds then release.
