Datoeter
Feb 25, 2020Aspirant
Orbi satellites do not connect anymore
Hi All, Till yesterday my Orbi's worked fine, i have two indoor satellites and one outdoor satellite. Now i seems that the router cannot connect with the satellites. I tried rebooting, manual syn...
- Mar 04, 2020
Hi all,
I returnened the Orbi set and got a new set. The old set was faulty. I connected the new set, there were no problems.
Thank you all for your help.
Retired_Member
Feb 25, 2020
FURRYe38 wrote:Try a factory reset on the RBR and ALL RBS. Bring the RBS near the RBR and try to add them, 1 at a time. 6-10feet.
Let us know if this works, if so, then place the RBS back in there remote locations.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
any comment on the FW numbers??
Feb 25, 2020Guru - Experienced User
RBSY FW version will differ from RBR/RBS. Depending upon the mode. Most recent version doesn't match up with RBR/RBS. Doesn't seem to keep in line with RBR/RBS versions. Just as long as the RBSY is using the latest version available.
RBR/RBS has v2.5.1.8 for manual update if they choose to manually update here.
- Retired_MemberFeb 25, 2020
That's right...the OP has the OUTDOOR device. :smileyhappy:
