Datoeter
Feb 25, 2020Aspirant
Orbi satellites do not connect anymore
Hi All, Till yesterday my Orbi's worked fine, i have two indoor satellites and one outdoor satellite. Now i seems that the router cannot connect with the satellites. I tried rebooting, manual syn...
- Mar 04, 2020
Hi all,
I returnened the Orbi set and got a new set. The old set was faulty. I connected the new set, there were no problems.
Thank you all for your help.
Feb 25, 2020Guru - Experienced User
I would manually re-load the FW file from NG support site to the RBR using Opera or IE11 or FF. Download the FW file and unpack it and send the unpacked file to the RBR, let the RBR process it, then press the reset button on the RBR for 15 seconds then hit the sync button on the RBR then RBS and see if it will sync correctly and see if these odd characters go away. If they don't and the RBR doesn't seem to work correctly, I presume the RBR is faulty at this point and needs to be replaced.
Datoeter
Mar 04, 2020Aspirant
Hi all,
- FURRYe38Mar 04, 2020Guru - Experienced User
Thanks for letting us know.
Enjoy. :smileywink:
- SnorkyMNMar 04, 2020Aspirant
Hi. My satellite seems to be dropping daily, after working well for quite a while. Possibly the problem started after the last firmware update. I don't see anything in the normal logs that shows a drop, but my wife is using connections through there and it seems to die randomly. Sometimes it dies when I use a cordless phone near the base, which is on a 5.8GHz connection. But sometimes it just randomly drops her network connection briefly. I'm not exactly sure where to try the new channel for 5GHz for the connection between the Orbi and Satellite. I've looked through menus, but have not seen anything obvious. The status usually shows "Good" for the connection to the Satellite. The Orbi is upstairs in one corner of the house, the other downstairs on the opposite side of the house. Maybe 15-20 steps if I were to go through walls. Router Firmware Version V2.3.5.30, also the RBS50 is same version.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Other 5Ghz devices can effecit Orbis Wifi like your phone. Not much can be done about the phone. Might find a different phone that works on a different frequency. Like 900Mhz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
SnorkyMN wrote:Hi. My satellite seems to be dropping daily, after working well for quite a while. Possibly the problem started after the last firmware update. I don't see anything in the normal logs that shows a drop, but my wife is using connections through there and it seems to die randomly. Sometimes it dies when I use a cordless phone near the base, which is on a 5.8GHz connection. But sometimes it just randomly drops her network connection briefly. I'm not exactly sure where to try the new channel for 5GHz for the connection between the Orbi and Satellite. I've looked through menus, but have not seen anything obvious. The status usually shows "Good" for the connection to the Satellite. The Orbi is upstairs in one corner of the house, the other downstairs on the opposite side of the house. Maybe 15-20 steps if I were to go through walls. Router Firmware Version V2.3.5.30, also the RBS50 is same version.
- Retired_MemberMar 04, 2020
Datoeter wrote:Hi all,
Amazing.....
If you read my note, I have no idea where to set the channel between the Orbi and its satellite. It is probably only 30 feet away as the crow flies. (though a door and wall in the way, though one is upstairs, the other downstairs) Orbi is attached to Arris sgb6580 for internet traffic. I am attached to the Orbi directly and never lose connection, it's only through the Satellite that the connection drops. Almost always when I am on the handheld phone, and then sometimes just randomly. is there a log to find out why it's dropping? There are WiFi neighbors, as I'm in a townhome. When I watch and refresh, the Backhaul status always says Good.
Your ISP modem already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeTry setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. You set this on the RBRs web page using a web browser.
If you do have near by wifi neighbors you can try this as well, set the power levels of the RBR from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless SettingsTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Also factory rest the RBS and see if it will resync it self. Press the back reset button for 15 seconds then release. May need to press the sycn button on both RBR and RBS it the RBS doesn't auto sync itself.
SnorkyMN wrote:If you read my note, I have no idea where to set the channel between the Orbi and its satellite. It is probably only 30 feet away as the crow flies. (though a door and wall in the way, though one is upstairs, the other downstairs) Orbi is attached to Arris sgb6580 for internet traffic. I am attached to the Orbi directly and never lose connection, it's only through the Satellite that the connection drops. Almost always when I am on the handheld phone, and then sometimes just randomly. is there a log to find out why it's dropping? There are WiFi neighbors, as I'm in a townhome. When I watch and refresh, the Backhaul status always says Good.
The arris is not routing, and is already in bridge mode and is not doing any routing or wifi or anything else.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. You set this on the RBRs web page using a web browser. "
Yes, and I ask again, where am I supposed to set this going to the satellite? There are tons of tabs and areas for settings and I don't see anything specific for going to the satellite. (Which is talking on 5GHz)
You only set channels on the RBR. The RBS doesn't set channels it will follow and connect to what ever the RBR is using.
Yes, but where to set the channels for the connection to the Satellite?
On the RBRs web page you can change channels there. Basic Tab/Wireless.
There are not channels to change for the RBS. What ever you set on the RBR the RBS will follow.
Only channesl to change are the 2.4Ghz and the 1 5Ghz radio. The wireless backhaul can't be changed as thats handled automatically. This is not user configurable.
