n19htmare
Jan 09, 2020Aspirant
Orbi satellites [RBS50] dropping connection
Dear Netgear. I have one Orbi router [RBR50] and 2 Orbi satellites [RBS50] in a Daisey chain. The backhaul status is always 'good' in the settings. Every few days the connection to satellites s...
n19htmare
Jan 14, 2020Aspirant
Sadly it's just happened again on the latest firmware. It seems to be the first satellite in the daisey chain that's dropping. Not sure if it's in my head of coincidence but it seems to happen more often when it's raining.
Jan 14, 2020Guru - Experienced User
What happens if you swap RBS around in the chain?
Has a factory reset and setup from scratch been performed since the FW update?
- n19htmareJan 15, 2020Aspirant
Trying that now. Will let you know how I get on.
- FURRYe38Jan 15, 2020Guru - Experienced User
:smileywink:
- n19htmareJan 17, 2020Aspirant
No joy. I find that it's okay on 5ghz backhaul but problems happen when it moves to 2.4Ghz backhaul. Strange thing is that on 5Ghz backhaul has good connection so dont know whn it falls back to 2.4ghz in the first place.
Also tried using as an AP but still has the same problem with satalite dropping when the backhaul is 2.4Ghz.
Not sure what to try next?
