Orbi
Dec 16, 2016Star
Orbi Satellites show wrong region
After upgrading the firmware to the latest, and a factory reset with the pin, the satellites still show region Europe. This needs to get fixed. There isnt even a way to remove a satellite. I have 2...
- Jan 14, 2017
I just factory reset mine and it now says North America.
apbrenner
Jan 14, 2017Aspirant
I have the same issue.. I have to satellites and one of them was switched to Europe region with the last auto update of the firmware to
- Hardware Version: RBS50
- Firmware Version: V1.4.0.34
I confirmed it's a US model and that my router is set to US. It's only an issue with one of the two RBS units. I have done a reset and manually reapplied the firmware but no change
- st_shawJan 14, 2017Master
My satellite also shows Europe. As far as I know it always has. I'm now on Firmware Version: V1.4.0.34.
Does it matter though? The system seems to work OK.
