Orbi_Amatuer
Jun 25, 2020Aspirant
Orbi Satellites
I have an Orbi system with 2 Satellites.
I have a question about the "Attached Devices" list as seen when logged into the Router as administrator.
Each of my my satellites have unique names.
So I can see which device is connected to what satellite in the "connected orbi" column.
Example: iPhone A connected to Orbi 1.
However, I have a couple devices that sometimes show connected to "Orbi Satellite" but not specifying which satellite it is actually connected to.
Does this imply it might be trying to connect to more than 1 satellite?
Kind of like it's trying to make a decision for which satellite to connect to based on signal strength?
Hoping to learn more about this.
Thanks.
To see which RBS a device is connected too, log into the RBSs web page and review the connected clients on each RBS there.
- Orbi_AmatuerAspirant
Ah Ha.
Are you telling me there is a way to login directly to a sattellite to view connected devices in addition to logging into the router to see the connected devies?
If my undersanding is correc, tHow do I get to the login of each individual satellite?
Yes, Look for the IP address assigned to the RBS on the RBRs web page. Use this address and same RBR log in info on the RBS web page.
