Chip9399
Oct 13, 2021Follower
Orbi satilite hardwired but no wifi from it? Help please
Ok struggling to get satilite to broadcast wifi, here's my setup; rbr50 plugged into isp(yellow) 2 rbs50 in house working fine, 1 rbs50 hardwired to barn 150ft away, shows up in app as wired, but it will not broadcast a wireless wifi signal, if I hardwire into back of barn rds50 to laptop I get internet! , but no wireless signal. ?
Sort By
What happens if you swap RBS with each other? Problem follow?
Have you factory reset the RBS, powered if OFF fully for 1 minute then back ON then wirelessly sync it to the RBR while near or in same room as RBR to trouble shoot this? If the RBS is bad, then it won't sync wirelessly to the RBR.
Do you know if the FW version is the same version on the RBR as whats loaded on the RBS?
If you swap it with one in the house, is it still that specific model not broadcasting?
If you log into that specifics IP address, what does it show on the status page for the wifi?
