Kentboyjohn
Feb 22, 2020Aspirant
Orbi Sattelite keeps dropping out
I am fed up with my Orbi Sattelite keep dropping connection. I have had it in the same position for 2 years and all was perfect but the last couple of months it drops every day several times and I h...
Feb 23, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- KentboyjohnFeb 23, 2020Aspirant
You ask so many questions it's almost like it will be my fault. It's been working fine for two years and now it's crap so can only be a software update that's screwed it. I paid £350 to have it work not to employ a data engineer with it.
- Retired_MemberFeb 24, 2020
Kentboyjohn wrote:You ask so many questions it's almost like it will be my fault. It's been working fine for two years and now it's crap so can only be a software update that's screwed it. I paid £350 to have it work not to employ a data engineer with it.
So start at the beginning....."What Firmware is currently loaded?" And while you're at it, share with us how you came about this FW?
- FURRYe38Feb 24, 2020Guru - Experienced User
Please don't take the questions as being your fault. Questions are to gain more information from you about your system and how it's configured and some suggestions on some troubleshooting steps to see if they may help. There are many factors in WiFi, problems and trying to help you figure this out. The more information and feedback you can give us the better. If you feel that your overwhelmed by all this, you may need to see some local help from experienced technician that can come to your place to help you out witht this.
- KentboyjohnFeb 25, 2020Aspirant
Firmware is V2.5.1.8
Modem is a DFRAYTEK Vigor 130
Home is a small detached house and the satellite is on the same floor and no more than 18 feet away from the router
I HAVE TRIED ALL THE VARIOUS CHANEL SETTINGS SUGGESTED
4 Neighbours showing + My Sky Box and HP Printer and some Google speakers/hubs
I am beginning to pull my hair out with it.
I have factory reset but makes no difference
- FURRYe38Feb 25, 2020Guru - Experienced User
Kentboyjohn wrote:Firmware is V2.5.1.8 OK Here
Modem is a DFRAYTEK Vigor 130 OK Here.
Home is a small detached house and the satellite is on the same floor and no more than 18 feet away from the router< This is too close distance between the RBR and the RBS. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- Retired_MemberFeb 25, 2020
Your're overlooking this fact:
"... have had it in the same position for 2 years and all was perfect but the last couple of months it drops every day several times and I have to reboot it every time. "
