mapalm418
Oct 07, 2021Aspirant
Orbi Says My iMac Is Not Connected to The Network, But It Is
I am running a network with RB20 satellite and router. When I try to log into the Orbi Admin page, I get a web page that says I'm not connected to my Orbi Network, but I obviously am. My Mode...
- Oct 07, 2021
Another update:
So ATT restored the connection.
Then, they manually went in on their end and disabled the WiFi radio signals. So now the ATT modem/router is no longer broadcasting a WiFi signal, effectively making it a modem only.
The rep explained that the user tools are much less sophisticated, which is why they were able to do it on their end.
Thanks so much for your help! It got me close, then calling in to ATT helped finish the job.
By the way, now that I no longer have a Double NAT situation, what kind of improvements can I expect to see?
Oct 07, 2021Guru - Experienced User
Do you have a screen capture of what your seeing. Please use the Choose File button to attach a screen shot of what your seeing.
What browser are you using? Try a different browser?
- mapalm418Oct 07, 2021Aspirant
Firmware is V2.7.3.22
The ATT modem is Arris BGW210-700
On the Orbi App on my iPhone, I see that my iMac is connected to my network (and I am connected). But when I try to log into the Orbi login page on my iMac's web browser (tried both Safari and Firefox, caches cleared), I get the Orbi landing page that says I'm not connected to the Orbi Network.
Also, my HomePod mini does not show up in the Orbi app but it is obviously connected to WiFi, too.
I also have another issue that I posted about, too:
- FURRYe38Oct 07, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option#2 first, if not, #3 lastly.
Edit: ATT helped me configure the modem using Passthrough, so your Option 2 below.
Thanks. When I first set up ATT internet at home (about 2 months ago), I talked to ATT and I'm pretty sure they walked me through your Option 1 detailed in your post. But maybe not.
I do see the wifi network broadcast by the ATT modem/router, but we ony connect to the Orbi network. We have no devoices connected to the ATT wifi network.
