mapalm418
Oct 07, 2021Aspirant
Orbi Says My iMac Is Not Connected to The Network, But It Is
I am running a network with RB20 satellite and router. When I try to log into the Orbi Admin page, I get a web page that says I'm not connected to my Orbi Network, but I obviously am. My Mode...
- Oct 07, 2021
Another update:
So ATT restored the connection.
Then, they manually went in on their end and disabled the WiFi radio signals. So now the ATT modem/router is no longer broadcasting a WiFi signal, effectively making it a modem only.
The rep explained that the user tools are much less sophisticated, which is why they were able to do it on their end.
Thanks so much for your help! It got me close, then calling in to ATT helped finish the job.
By the way, now that I no longer have a Double NAT situation, what kind of improvements can I expect to see?
mapalm418
Firmware is V2.7.3.22
The ATT modem is Arris BGW210-700
On the Orbi App on my iPhone, I see that my iMac is connected to my network (and I am connected). But when I try to log into the Orbi login page on my iMac's web browser (tried both Safari and Firefox, caches cleared), I get the Orbi landing page that says I'm not connected to the Orbi Network.
Also, my HomePod mini does not show up in the Orbi app but it is obviously connected to WiFi, too.
I also have another issue that I posted about, too:
Oct 07, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option#2 first, if not, #3 lastly.
- mapalm418Oct 07, 2021Aspirant
Edit: ATT helped me configure the modem using Passthrough, so your Option 2 below.
Thanks. When I first set up ATT internet at home (about 2 months ago), I talked to ATT and I'm pretty sure they walked me through your Option 1 detailed in your post. But maybe not.
I do see the wifi network broadcast by the ATT modem/router, but we ony connect to the Orbi network. We have no devoices connected to the ATT wifi network.
Just a follow-up.
ATT had me configure the Passthrough mode 2 months ago. I just did it again (I kept the notes) and restarted the ATT modem.
However, I still see the WiFi network that is being broadcast by the ATT router. Is that normal?
I also still see the wrong MAC addresses for some of my devices that are connected to my Orbi WiFi network.
- FURRYe38Oct 07, 2021Guru - Experienced User
The WiFi radios on the ATT modem need to be fully turned OFF.
Power OFF the RBR and RBS. Leave the RBS off, turn ON the RBR and check the connected devices list.
What devices are appearing out of spec?
Is it safe to just toggle those buttons off on the ATT modem/router admin page? And I assume I'd turn off both 5ghz and 2ghz?
As far as the devices showing the wrong MAC address, someone else in another post mentioned Randomized MAC addresses. I think that's part of the issue.
But that still leaves the bigger issue of my Double NAT.
