batpot
May 18, 2019Tutor
Orbi says zero satellites connected... But have Ethernet
Bought a package with the rbr20 router and 2 satellites. The satellites are connected to Ethernet as well, so it is doubly confusing why it can't see them. None of the units have lights on, which is...
batpot
Jul 21, 2019Tutor
Did a fresh install, which turned into a real PITA, because even after deleting the satellites, and factory resetting them, they would never be found by the app.
Had to also factory reset the router. After resetting router into AP mode, same issue - logging into the router via web interface shows 2 satellites, but app still shows zero.
Firmware is V2.3.5.26 on all devices. App version is Android 2.3.7.622.
