dkpilgrim
Feb 08, 2017Initiate
orbi schedule does not work
I setup orbi schedule to turn off from 12:00 am to 6 am. It did turn off but cannot turn on anymore. need to reset to get wifi work. Any idea?
gfrey
Feb 28, 2017Apprentice
dkpilgrim wrote:I setup orbi schedule to turn off from 12:00 am to 6 am. It did turn off but cannot turn on anymore. need to reset to get wifi work.
Any idea?
Check that your Orbi has the correct Date/Time. I have found mine not picking up the Date/Time from Netgear NTP servers as I use the Block Services per Schedule. I have even resorted to using Telnet to set the Date/Time manually at times. My Orbi has the correct Date/Time with the latest firmware after a reboot. You can check the Date/Time on your Orbi under Advanced tab - Security --> Schedule. At the bottom will show the Current Time. I just thought that might be your issue...
