Jemill00's avatar
Jemill00
Orbi Secure Device Connection
I've been using my RBR50 and Satellite for several months and suddenly a couple devices stopped connecting to the secure side of the router. My Honeywell thermostat and Furbo (dog camera/treat launch...
  • Jemill00's avatar
    Jemill00
    Nov 01, 2020
    Firmware is V2.7.1.60 and was just upgraded after the issue started.  It did fix it.
    I have engaged the Furbo support and the advised me to separate the 2.4 and 5GHz channels to connect directly to 2.4,
    Thanks
