dcdwek
Oct 19, 2020Follower
Orbi set up issues with Meraki MX 64
Hi I have set up my netgear orbi and satellite in AP mode. The Orbi is connected directly to a Meraki MX64 router and firewall. configurations are correct and a VLAN has been set up on the Meraki f...
Oct 19, 2020Guru - Experienced User
What happens if you log into the RBRs web page?
What happens if you remove the lan cable from behind the RBR for 5 seconds then plug it back in?
