gegger
Mar 18, 2019Aspirant
Orbi setting up backhaul with spectrum
my system Spectrum internet with Arris TM1602A MTA cable modem. RBR50 RBS50 and an RBS40
I am trying to get a morfe stable system and am looking at setting up wired backhaul with the orbi. can be...
gegger
Mar 19, 2019Aspirant
I’ll be working on it this weekend have to fish a couple cat 6 cables. What about a static ISP for router an satellites - regardless I will report back
FURRYe38 wrote:
Let us know if you were able to get this setup.
I am trying to get a morfe stable system and am looking at setting up wired backhaul with the orbi. can be very confusing... What settings for the orbi do I need to set in the advanced setup section. I have updated to the latest 2.3 firmware. do ineed to setup any thing different with the Arris. Today the orbi is set to router mode should i be in AP>? all suggestions appreciated thanks gegger
Mar 20, 2019Guru - Experienced User
You can use reserved IPs for satellites ON the router. Static isn't supported ON the satelites themselves. Reserved IPs is recommended for satellites. Keeps them connected at a particular IP.
- geggerMar 20, 2019AspirantOne more question since I’m running hardwire this weekend, any preferences for running cable from router to individual satellites or daisy cahin from router to one satellite and connect the last satellite off it
- FURRYe38Mar 20, 2019Guru - Experienced User
I recommend each satelllite connect directly to the base router. You can connect them daisy chain wired I believe, however if the in between satellite happens to experienece problems, this may effect the down stream satellite. So I would avoid this possibilty by direct connect each satellite to the base router for independent operation.
One last question I’m tech inclined but this is new to me. So I set up backhaul do you reccomend static ip for the router and the satellites. If so what do I use for the ip. Do i set the ip prior to syncing the satellites
