gegger
Mar 18, 2019Aspirant
Orbi setting up backhaul with spectrum
my system Spectrum internet with Arris TM1602A MTA cable modem. RBR50 RBS50 and an RBS40
I am trying to get a morfe stable system and am looking at setting up wired backhaul with the orbi. can be...
Mar 21, 2019Guru - Experienced User
Let us know if there is another disconnect again after the factory reset and setup from scratch.
Has the ISP modem and RBR been powered OFF for 1 minuted then modem back ON then power ON the RBR?
gegger
Mar 21, 2019Aspirant
yes I unplugged for at least a minute and did the sequence modem power up followed by router
- FURRYe38Mar 21, 2019Guru - Experienced User
ok, Lets see what happens since you've done a reset and setup.
When you updated FW, did you reset and setup again or just apply and continue wiht out a reset?
- geggerMar 21, 2019Aspirant
i did a full reset and setup
Ok, lets track this and see how far it goes.
Haven't seen anyone else with issues with the ISP modem since v32. Mostly configuration issues and wifi speeds.
If anything, can revert to v210. :smileyfrustrated:
