bhurt
Mar 10, 2019Aspirant
Orbi settings for nest protect
I cannot get my Nest Protects to connect to my Orbi router. I have tried every suggestion on the message boards and the Nest websites. I tried talking with Nest support but it was not helpful. I am ...
bhurt
Thank you for your response. I am trying to complete your steps but I don't know how to do this one: "Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above"
ekhalil
Mar 10, 2019Master
What computer OS do you use, Windows or Mac?
If you use Windows, just open the Command Prompt and type the following:
> telnet 192.168.1.1 (or use the IP address of Orbi)
