ChangXray
Jan 16, 2021Aspirant
Orbi setup: AC2200/RBK30 connecting to netgear modem CM500
Internet provider: Spectrum Xfinity cable Cable modem: Netgear CM5OO WiFi router: Netgear N600WND R3400 I just bought an ORBI AC2000/RBK30 and followed the orbi setup instructions. My iphone c...
alokeprasad
Jan 16, 2021Mentor
Yes, using a computer connectee to the router's ethernet port and using the Orbi's web interface is the best way of setting things up.
How do I set up my Orbi router and satellite?
My preference in in red in Steps 10, 11 in the above link:
- Connect your computer or mobile device to the Orbi router or satellite with an Ethernet or WiFi connection.
Note: To connect with WiFi, find the preset WiFi network name (SSID) and password on the label on the Orbi router or satellite and connect to that network from your WiFi-enabled computer or mobile device. - Download the Orbi app or visit http://orbilogin.com to set up your Orbi WiFi network.
The Orbi router's ring LED turns off after the setup is complete.
