tmlt0912
Apr 20, 2019Aspirant
Orbi setup and some questions
Hello,I have some orbi setting and setup questions.(Sorry my English is poor.)
Beacuse iOS disconnection issue,I referenced to https://bit.ly/2CoOybd
and my brother's Samsung is constantl...
- Apr 22, 2019
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Apr 22, 2019Guru - Experienced User
- tmlt0912Apr 23, 2019Aspirant
V2.3.1.48
DASAN H660WMWhat is the size of your home? Sq Ft?
I don't know...But router and satellite(s) distance one floor.
2.4Ghz channel is 1,and 5Ghz is 44.No,only Orbi in my house.
It' enable.
OK,So I will disable Daisy Chain, Fast Roaming, IPv6?
And how to Set 20/40Mhz Coexistence to 40Mhz?I only see "Enable 20/40Mhz Coexistence" chose...Thank you!
