corona247
Sep 02, 2020Aspirant
ORBI setup
Hello all. I have an netgear AX 12 router, and I just bought the ORBI RBK 752 with 1 satellite. I am unclear if I am settingi up my orbi correctly, and am looking for someone to critique m...
corona247
Thanks for the quick reply!
My orbi router is physically elsewhere in the house, connected to a wall ethernet port - this ethernet port connects to a LAN port on my AX 12 router.
Doesnt the ORBI satellite communicate to the ORBI router via a backchannel? and thus doesnt need to be directly connected via LAN to the ORBI router?
My ORBI router is not connected to a switch.
Thx!
CrimpOn
Sep 02, 2020Guru - Experienced User
Of course, you are correct. We get so many posts about ethernet backhal that I went off on a tangent. Sounds like you are set.
