ranzen
Dec 02, 2018Tutor
ORBI setzt die Glasfaser-Geschwindigkeit nicht um
Moin,
seit ca. einem Jahr wohne ich in einem Haus mit einem Telekom VDSL-Anschluß (100 MBit). Zur Verteilung des Internet-Anschlusses im ganzen Haus setze ich ein ORBI-System ein, bestehend aus...
ranzen
Dec 14, 2018Tutor
since about one year I live in a house with a Telekom VDSL connection (100 MBit). I use an ORBI system consisting of RBR40, RBS40 and RBW30 to distribute the Internet connection throughout the house. With the help of the ORBI system I have approx. 70-90 MBit everywhere in the house. In the study is the RBS40, to which I connected a fast Mac Mini 2018 directly via network cable. Also here I have about 80 MBit. So far, so good.
But now I have a fiber optic connection from Vodafone with 500 MBit since a few days. And now the problems start. Now I have tested all possible combinations for about 2 days with the result that I only have the full speed of 480-490 MBit directly on the fiber optic WLAN. The ORBI RBR40 router is connected to this fiber modem from Vodafone via CAT 6 cable (length 7.5 m). If I then use the WLAN of the RBR40, I have only about 90 MBit available. It is the same in the whole house. Even in the office of the RBS40 there is only less than 100 MBit available, so it makes no difference whether I use the WLAN in the ORBI system or connect my computers directly to the ORBI router via LAN cable. I always have less than 100 MBIt, even though almost 500 MBit go into it. I tested the WLAN with an iPhone 8, which can use almost 500 MBit directly on the Vodafone WLAN. In the ORBI system, however, only under 100 MBit.
Where is the brake in the system ?
Translated with www.DeepL.com/Translator
Dec 14, 2018Guru - Experienced User
What FW is currently loaded?
Did you power OFF The modem and Orbi router for 1 minute then power ON the new modem and let it synce then power ON the Orbi router and then test? You may need to factory reset the Orbi router and setup from scratch since you have changed ISP services, the system needs to be setup for the new. This time, ensure you don't enabled QoS, Traffic Meter or Access Controls on the Orbi router when setting it up.
