pensan04
Oct 16, 2019Aspirant
Orbi Showing WifI but not connecting to Internet
My current setup - Orbi RBR20 with 2 satellites. The router is in the center of my house and the two satellites spread out enough to give good coverage. House is less than 3000 sq ft. Modem is ...
Oct 16, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
