perrynmyers
Sep 27, 2020Star
Orbi Showing Wireless Devices as Wired in Attached Devices List
Hi, Issue: I have found that on RBR50 deployments where there are two satellites connected via Ethernet Backhaul, that the Attached Devices List will incorrectly show which Orbi device a network...
- Jan 21, 2021
Hi,
I just closed out my support case with Netgear on this issue. It took 4 months (opened in August, finally closed in January) and I spent much of that time being passed back and forth between support associates. But in the end, Netgear finally admitted to me the following about this particular issue.
From Support:
"I have confirmed with our engineers that the satellite has a limitation with reporting connected devices while its in ethernet backhaul as the router identifies that the wired backhaul connection of the satellite rather than the actual connection of the device to the satellite which are engineers a indicated that it is a limitation in the design of the system.
I apologize for the inconvenience. Let me know if you have questions or concerns."I then asked:
"Is it unfixable and therefore a product flaw that just needs to be lived with?"
And was told:
"As I have confirmed that this is a limitation as per our engineers. We were only informed of this upon consultation with our engineers and I sincerely apologize if it took awhile to get answers for you."
(Note: This answer from Engineering took 4 months to get to.)
So in short, the way the Orbi system is designed, it is impossible for them to report properly whether a device is Wired or Wireless if any of the satellites are using Ethernet Backhaul.
In my investigation into how the Orbi works (which under the covers appears to use technology provided by Fing to do device discovery), here is what I summarized based on a discussion with technical support at Netgear:
"After noting that all of the devices incorrectly labeled as Wired were coming from the RBS40V, you suggested that we remove the Ethernet backhaul from that specific satellite to see if it would correct the problem. I did this, and checked the Attached Devices list. I found that the RBS40V no longer reported any Wired devices at all. I also found that the RBR50 Attached Devices list was now 100% correct, and no longer incorrectly listed any wireless devices as Wired. You also mentioned that the Orbi's use Fing's software to do device collection. Perhaps the way the Fing utility is being run on the RBS40V is causing it to collect Wired devices instead of only reporting back the Wireless ones. Again, thank you for the call and helping to do some additional troubleshooting on this. I hope the above notes are helpful."
I also provided a potential software solution that could likely fix the problem:
"Each device (RBR50, RBS50, RBS40V) collects a list of devices it "sees". Each device knows which clients are connected wirelessly to it, and each device can see ARP requests for devices not connected to it and it detects those devices as "Wired". So, every device is both reporting "Wireless" devices accurately, and reporting "Wired" devices sometimes accurately, and sometimes inaccurately.
The right way to fix this would be for the RBR50 to have logic that preferred reporting Wireless if it gets conflicting information. For example: RBS40V reports a device as 2.4G, RBR50 reports same device as Wired. The RBR50 should "prefer" the Wireless reporting, since that is more accurate than the Wired reporting, and therefore should display the device as 2.4G. Right now, it appears to be a "random" determination as to whether the RBR50 will pick the Wired or Wireless designation for a device that is reported by multiple Orbi devices.
Further, Satellites (like the RBS40V and RBS50) can report Wired devices they see to the RBR50, but they should never list those as "locally connected". There's no way to determine if a wired device is connected to one Orbi device or another, so the default should be to always say that Wired devices are solely connected to the primary router (i.e. RBR50)
If the above logic was put into place, I believe this problem would be resolved."Given that a user would expect to see Wired and Wireless devices reported accurately, and there is a potential software solution to fixing this issue, I believe this absolutely is classified as a bug.
Netgear has chosen to not fix this issue, and that is of course their perrogative. Not all bugs are of equal priority, and this one being purely cosmetic perhaps does not rise to the level of importance to justify investment in it being fixed. And it could also be that the fix for this would be more invasive than is warranted for an existing deployed system. But, I did suggest to Netgear support that perhaps they could implement what I described above in future generations of Orbi systems if that was indeed a concern.
In the end, the answer I got indicated that it is a limitation of the system. But in a sense, any bug can be waved away as a limitation of the system. A bug is a bug, even if the software vendor chooses not to fix it. I am content with the response I got from Netgear, because they acknowledged this was an issue (by claiming it was a limitation of the design) and eventually letting me know that they would not address it. (I only wish that it didn't require countless hours of my time and literally 4 months to get there...)
On the other hand, this is a bug, and I would hope that in future generations of Orbi software that they fix it, and I believe that the mechanism I suggested above could do that.
If the software was Open Source, I likely could fix this myself... But I could only go so far in trying to fix the issue given that much of the Orbi software are composed of binary blobs without accompanying source code.
Best regards,
Perry
perrynmyers
Nov 03, 2020Star
My support case with Netgear to troubleshoot this really has made zero progress. Mainly because they keep asking me for times for their level 2 support engineers to call me, and then when the agreed upon time comes, no one calls because there is always a scheduling conflict on their end. I've had 6+ scheduled calls go this way over the last month and a half. So, because support seems unwilling to actually assist, I've done some debugging on my own and have figured out a few things.
(Note: I did end up removing the Ethernet switches between the RBS40V/RBS50 and the RBR50. So at this point, the RBS40V is directly connected via Ethernet cable to the RBR50. And similarly, the RBS50 is directly connected via Ethernet cable to the RBR50. The Ethernet switches are no longer in between any Orbi Devices)
1) I don't think Voxel's firmware is going to help, because ultiamtely Voxel is taking the stock Netgear firmware and updating the bits that can be updated (Open Source code, utilities, etc). But, the bits of Netgear's firmware that are proprietary can't be maintained or updated by Voxel. I think he's just using those as is. (For example the attached-devices/net-scan binaries)
2) I've observed by doing dumps of Attached Devices on the RBR50, RBS50 and RBS40V that the only devices that are misrepresented as Wired are devices that show up on the RBS40V as Wired. The RBS50 never reports Wired devices attached to it. It seems like the RBS40V is sending it's list of Attached Devices to the RBR50, and this contains a mix of attached 2.4G/5G devices as well as devices incorrectly determined to be Wired.
3) This likely causes the RBR50 to contain an attached devices list with duplicate MACs in it. For example, RBS50 reports Foo is connected to it's 2.4G interface. RBS40V incorrectly determines that Foo is Wired (because it is not attached locally) and reports that back as well. Now, when the RBR50 is generating the DEV_show_devices.htm page, whatever row comes up first wins. If the row submitted by the RBS50 is first, the Foo will show correctly as 2.4G and associated with the RBS50. But, if the table has the row from the RBS40V first, it likely results in the device being incorrectly shown as Wired and associated with the RBS40V. I think this is the case because the RBS40V (via looking at its DEV_device.htm page) always shows more Wired devices attached to it than the RBR50 shows as being associated to the RBS40V). And also, the set of Devices that the RBS40V reports incorrectly as Wired seems to be fairly static, but the set of devices the RBR50 ultimately reports incorrectly as Wired is a subset of those that varies from query to query over time.
4) Looking at the source code for the RBR50 (https://www.downloads.netgear.com/files/GPL/orbi-desktop-V2.7.0.70_gpl_src.zip) I was able to figure out that the souce for the DEV_show_devices.htm page come from files in /tmp/netscan. These files are generated via net-scan binary that in the source zip come from a proprietary attached-devices binary.
So, in short... I think if I was able to see the source for attached-devices/net-scan binary, so that I could see how the files in /tmp/netscan are generated, I'd likely be able to propose a fix for this bug. It could be as simple as "If a Satellite reports a Wired device attached to it, but the Router or another Satellite says that that same MAC is Wireless 2.4G/5G, then trust the device that reports the device as Wireless over the device that reports the device as Wired"
Unfortunately, since the attached-devices/net-scan binary is proprietary I can't proceed further with debugging. I have asked Netgear support if they can confirm my hypothesis or give me access to the source code so that I can debug further.
Nov 03, 2020Guru - Experienced User
Ok.
