Elmo33
Jan 25, 2019Aspirant
Orbi shows connected to internet but no internet access
I have an RBK50 system which was working fine. I suspect a new firmware was automatically downloaded and on install completely bricked the router. I have a backup RB50 due to buying an extra satell...
Jan 25, 2019Guru - Experienced User
Did you power OFF the ISP modem and orbi, then power on the modem and let it sync then power ON the Orbi router and the test the connection?
Make sure your PC and devices are setup for networking to auto obtain IP addresses from the router.
Direct connect a wired PC to the ISP modem to check internet there as well first.
The systems FW is kind of old, so to get upto date on FW, first you need to download v2.0.0.74 and v210 for both router and satellites. First apply the v2.0.0.74 to the satellites, then the router. After this has been performed, then apply v210 to the satellites then the router. You'll be up to date.
Elmo33 wrote:
I have an RBK50 system which was working fine. I suspect a new firmware was automatically downloaded and on install completely bricked the router. I have a backup RB50 due to buying an extra satellite. I set up that one and it shows good connection to all satellites and to the internet (cable modem - tp link). Despite this there is no internet on wifi or on wire connection through the router. Internal wifi things work (including somethat require internet - internet connected switches) but we can't access web pages, netflix etc. Everything times out. Firmware is .18. (I've power cycled everything without improvement, direct ethernet to the modem works fine so I'm sure it's the Orbi). Any help is much appreciated. Also there should be some kind of consensus movement with Orbi to stop these automatic firmware updates. My system worked completely fine prior to this.
Elmo33
Currently not at home but will answer what I can.
Direct ethernet into the modem from computer works fine. I did power cycle both the modem and the orbi without any improvement. Initially when it was installed Orbi had me power cycle the modem which seemed to work for about an hour then it stopped. I will re-power cycle both when I get home.
modem is a TP-link tc7650
Devices should all be on auto-obtain IP
Thanks!
- FURRYe38Jan 25, 2019Guru - Experienced User
I would do this, power off the modem for 30 seconds. Then factory reset the Orbi router. With a wired Pc connected to the Orbi router, log into orbilogin.com and walk thru the setup wizard. This will check internet has it goes along. It should help you get connected.
Let us know.
