Lavolpe
Jun 15, 2018Aspirant
Orbi signal range
OK I have this odd issue. I thought it was just my orbi malfunctioning for some reason. It has come to my attention that there is another Orbi around my area, but the thing it would have to be within...
Jun 16, 2018Guru - Experienced User
Any chance you could use a mobile device or laptop and find the location of this orbi thats not set up and maybe talk to the owner about it?
I would find out what channels this orbi is using then manually change your to farthest channels from this one orbi thats it's using...
You can lower the power output of your orbi from 100% to 75% and see. You'll have to move satellites a bit closer possible to make up for the reduction in signal.
