DCP4971
Jun 22, 2020Luminary
Orbi slow switching devices between satellites
Hi all, I've added a second satellite to my Orbi network and had it in situ for a month or so but I notice that the system seems a bit dimwitted when moving around the house, very often leaving devi...
schumaku
Jun 22, 2020Guru - Experienced User
Fast Roaming must be enabled. In general, the 802.11 Working Group standards k, r, and v let clients roam more seamlessly from access point (AP) to AP within the same network. 802.11r is indeed for the business networking with WPA2 Enterprise - correct designation is "Fast BSS Transition (FT)" so not available on most consumer, SOHO and SMB wireless systems.
If you disable Fast Roaming here, the clients will stick with the BSSID (the named radio connection from one AP/radio) until the connection does fall under the typically very low signal level and quality. This behaviour is named sticky client.
DCP4971
Nice one, thanks for the pointer, will give it a whirl and see how we get on. It's easily reverted if there are unwanted side effects.
