Hamstar
Jun 22, 2018Guide
ORBI slow upload after 2.4.1.16 firmware update
I am a new ORBI home user. I installed my ORBI system on 6/9/18 on AT&T -verse 1000. It was setup in ROUTER mode by default. My download/upload speeds were pretty good -- about 600-800
I swi...
dmhayes007
Sep 28, 2018Tutor
I manually downloaded previous version of FW I was on (i think 2 versions back) and things are perfect again. The number of folks that seem to be complaining about this tells me it is bad FW and should be pulled. Also, I don't plan on going through the hour long 'from scratch' setup. I'll stay on this FW until Netgear releases a stable update.
Sep 28, 2018Guru - Experienced User
Good Luck.
Even when NG releases another FW update, you'll need to do another factory reset and set up from scratch if you seem to experience continued problems.
