sjemmett
Apr 02, 2019Aspirant
Orbi software change without notice
Im curious where, in the T&C for netgear I agreed to when registering my Orbi, I said it was OK for Netgear to do software uploads to my Orbi without my knowledge and permission? Between last night ...
doesorbiwork
Apr 03, 2019Tutor
Detailed description of current condition in "RBR20 stopped working"
Two satellites
Motorola Surfboard SB6141 Cable Modem
No idea what you mean by "mode of orbi operation". I plugged it in, set it up per the instructions and didn't touch it again until it failed.
Apr 03, 2019Guru - Experienced User
Power OFF the ISP modem and RBR for 30 seconds. Power ON the ISP Modem and let it come to ready. Then power ON the RBR.
Besure to use a good quality LAN cable between the ISP modem and RBR, CAT6 is recommended.
Your Orbi is running in Router mode.
Are you seeing which LED color on top of the RBR when this problem happens?
Two satellites
