rhester72
Dec 01, 2016Virtuoso
Orbi software deconstruction
This sort of information seems to interest people, so I'm going to share my *VERY RAW* notes about some interesting things I've observed under-the-hood on the Orbi. I'm far from done, but a good num...
rhester72
Well, I at least finally figured out how to see the actual signal strength between the router and satellite.
From the router, issue:
wlanconfig ath01 list sta
You'll get output like:
ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI IDLE TXSEQ RXSEQ CAPS ACAPS ERP STATE MAXRATE(DOT11) HTCAPS ASSOCTIME IEs MODE PSMODE aa:04:60:17:35:8f 1 4 192M 192M 43 38 48 0 0 65535 EPSs 0 f 0 APM 06:51:15 RSN WME IEEE80211_MODE_11NG_HT20 0
Would be kind of useful to expose some of it in the UI. :P
Note you can derive -dBm from Atheros RSSI by subtracting 95 from the value.
Rodney
peteytesting
Dec 01, 2016Hero
rhester72 wrote:Well, I at least finally figured out how to see the actual signal strength between the router and satellite.
ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI IDLE TXSEQ RXSEQ CAPS ACAPS ERP STATE MAXRATE(DOT11) HTCAPS ASSOCTIME IEs MODE PSMODE aa:04:60:17:35:8f 1 4 192M 192M 43 38 48 0 0 65535 EPSs 0 f 0 APM 06:51:15 RSN WME IEEE80211_MODE_11NG_HT20 0Would be kind of useful to expose some of it in the UI. :P
Rodney
pretty sure you are looking at the 2.4 gig there not the backhaul , the last bit suggest it is
MODE_11NG_HT20
as if the tx and rx where only 192M the backhaul wouldnt be usable
now if you want to di , try and find out how the backhaul is connected and if you can manage to get a standard client to connect to it
prob best however not post it or anything else here as the mods might get a bit narky if you expose too much of the under the hood stuff , doesnt mean you cant start your own blog and do your own project :)
- rhester72Dec 01, 2016Virtuoso
Right you are - will correct the example and output. (Ironically, the MAC matches what's displayed in the UI associated with the satellite - which is _not_ correct!)
I know how the (wifi) backhaul is connected, and yes, you can connect a standard client to it - all you need is the hidden SSID (last two digits are "unique") and the password (which is random and better done by copy/paste than trying to hand-enter, though presumably you could override it). It would be quite trivial to convert backhaul to another legitimate standard SSID, but would not be persistent across reboots.
Rodney
- TheEtherDec 01, 2016Guru
peteytesting wrote:prob best however not post it or anything else here as the mods might get a bit narky if you expose too much of the under the hood stuff , doesnt mean you cant start your own blog and do your own project :)
There are other similar threads, such as the megathread on the DGND3700. I'm hoping the moderators will allow this, so long as vulnerabilities are not disclosed.
- peteytestingDec 01, 2016Hero
i would agree that it would be good but its prob not a good idea untill at least the dev team have finished introucing new features and at least got to a stable all working platform to then start diving under the hood
- rhester72Dec 03, 2016Virtuoso
Very well.
One last bit of fun for now, then.
Since the Orbi is supposed to look vaguely nouveau-art, enjoy the light show!
while [ 1 ]; do for color in red green blue white amber cyan magenta; do /sbin/ledcontrol -n all -l on -c $color -s on; sleep 2; done; done
Rodney
