anirban3
Apr 29, 2021Aspirant
Orbi Speed Drop & Needs Reboot - RBR 50 & RBS50
Hello Everyone,
My ISP Connections gives me ~ 350MBPS Download & 350MBPS Upload. For the Last few days I'm getting 90 MBPS on the RBR & RBS. While if I reboot I get it at > 320 MBPS upload and download. But in a few hours it drops to ~80-90mbps. Which when I hard boot the router again goes back to > 320MBPS.
I have 10 devices connected
- Samsung Smart TV
- Amazon Firestick
- 3 Smart Phones
- 2 Ipads.
- 2 Laptops
- 1 Smart Hub
I'm running the latest firmwar on RBR & RBS - V2.7.2.104IN.
Connection Type 5 Ghz
Can someone please help resolve this.
Thank you
Anirban
Sort By
- anirban3Aspirant
When I check for a Firmware Update. It says its up to date. Which one do you recommend.
anyone else with the same firmware facing the same issues.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Traffic Meter, Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
anirban3 wrote:Hello Everyone,
- Samsung Smart TV
- Amazon Firestick
- 3 Smart Phones
- 2 Ipads.
- 2 Laptops
- 1 Smart Hub
Thank you
Anirban
