mds818
May 18, 2017Aspirant
Orbi Speed isn't fast enough
Hi All,
I am on Time Warner/Spectrum and use their Ubee cable modem with my MacbookPro and Orbi systen. When I had an Apple Airport Extreme, I got 300mbps + speeds but it was unstable. Now that i have the two Orbi system, it's more stable but my speed caps out at 215mbps or so. TW says I should be getting higher speeds and I agree, but Netgear charges to resolve the issue (I'm in month 4 of my purchase), so I figured I'd get advice here. I'm sure it's some setting somewhere I need to check. How can I crank this up to get the optimal speeds available?
Any help is appreciated, thanks.
hi the wan to lan speeds have been tested at
tcp - 924
udp - 406
what method are you using to test speed
have you tried disabling wwm
- mds818Aspirant
Hi,
Using speedtest online and the app from my desktop. Havent disabled wwm but afraid to based on online feedback.
- tomsliwowskiApprentice
Is your MacBook Pro hardwired or wireless? I'm assuming wireless since you mention instability on the AAE. Running iperf between my router and sattelite I get about 350Mbps. However running iperf between the router and a Linux laptop I get around 200Mbps. Keep in mind the router has a floor and a lot of plumbing in between so the speed would be hurt by that.
- tomsliwowskiApprenticeMake sure implicit beam forming and mu-mimo are enabled. The settings are in advanced->advanced setup->wireless settings.
