RXIT
Dec 20, 2017Guide
Orbi Speed Issue wired and wireless
I have used a Netgear nighthawk for the past couple of years and was pleased. We started to have some issues with the old router so I thought I would upgrade to the newer Orbi system about 3 w...
joshjoshjosh42
Dec 22, 2017Guide
I had this issue too - switching the Orbi system to AP and using a cheap router seemed to do the trick.
- RXITDec 22, 2017Guide
Josh, thanks that is something I have not tried yet, but have what I need to do so today. How long has your system been up an running with this set up?
One of the more disappointing issues for me, is that Netgear has still never responded to my inquiry for support. Of course, if I can fix it this easily, then I don't need them.
I appreciate the suggestion. This will likely be my last attempt with Orbi.
This seemed like a fix, then it went it down hill a little bit ago. Frustrating as the potential is definitley there with the system
I finally got a response from support. They had me try the following.
Under advanced- setup- WAN setup- change MTU size from 1500 to 1450
Advanced- Advanced setup- wireless settings uncheck enable daisy-chain topology
Change the 2.4 band from auto to channel 6.
This has worked for the past couple of hours.
Also, while looking at the logs under administration, I see DoS attacks IP Spoofing from source is my Orbi Satellite. Is this a bug?
