Instarand's avatar
Instarand
Orbi speed tests
Hi folks. When I run a speed test from my Orbi app on my iPhone, I am seeing download around 600 and upload around 700. However, when I run a speed test from “Speedtest.net” Standing 10 feet from the router I get 200 down and like 30 up.
I have Optimum Altice 1GB fiber. I have the optimum router plugged into the Orbi router, and Orbi router set in AP mode with 2 satellites connected. All my devises are connected to the Orbi SSID not the Altice box which broadcasts a different SSID.
Not sure if my setup matters or not. But I find it strange the Orbi is reading such fast speeds at the wire, yet standing right next to it the wireless tests are so drastically different. Any ideas?
1 Reply
    Try the steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944.  Wireless speeds are limited by AC/AX and environmental conditions.  You also seem to have Double NAT and that will limit wired and wireless speeds.  The best comparison will be to run speedtest.net on a wired device plugged into the Orbi base and compare to speedtest.net on a wireless device, not rely upon the Orbi's app/admin website speed test.
