Themooingman
Mar 11, 2017Tutor
Orbi speed
Hi after reading many reviews got an orbi and 1 satellite today. Using it with an asus ac68u modem router. Orbi was a breeze to set up. Wifi coverage in the house is good and generally stronger ...
Themooingman
Mar 11, 2017Tutor
Hi Mikey thanks the response how can I tell what ghz they are connecting at ? My old router I would tell to connect to 2.4 or 5 ghz as you could have the 2 ssid being broadcast ? On the orbi I just have one orbi being broadcast ?
Sorry if if I am missing something obvious. Your further help appreciated
thanks
st_shaw
Mar 12, 2017Master
Themooingman wrote:how can I tell what ghz they are connecting at ?
Go to http://orbilogin.net/DEV_show_device.htm The column at the right side of the table should show what connection type is in use for each device: wired, 2.4G, 5G.
- Butch1326Mar 12, 2017Star
Food for thought. I do this with my Netgear R8500 router.
I setup the Orbi in AP mode with only the 5ghz radio turned on. The 2.4ghz wifi radio is turned off on the Orbi. I use my main router with only the 2.4ghz on. This allows me to maintain 2 separate wifi networks for 2.4ghz and 5ghz.
This sounds like it will work in your configuration with the Asus router you mentioned.
- ThemooingmanMar 12, 2017Tutor
Mikey thanks but my right hand column just shows wireless. Not mention of 5 ot 2.4 ghz ? Confused
On the Orbi router uncheck go to Advanced Setup - Wireless Settings and uncheck both Enable SSID Broadcast and Enable Wireless Router Radio under the 2.4ghz section
- st_shawMar 12, 2017Master
Themooingman wrote:Mikey thanks but my right hand column just shows wireless. Not mention of 5 ot 2.4 ghz ? Confused
The following steps will enable display of the wireless bands. Use at your own risk. If you are uncomfotable with this, there is at least one other way to see the wirless bands that has been posted on this forum. Search this forum.
Debug PageEnable Advanced Device Display on Router- Go to the debug page and enable telnet- Telnet into the router- Execute the following:nvram set enable_adv_attached=1nvram commit- Exit telnet- Go to the debug page and disable telnet (please don't forget this step!)- ThemooingmanMar 12, 2017Tutor
Butch thanks. Done this now shows 2.4 disabled.
Mikey thanks i used butchs method. Now as only the 5 ghz is working. I'll connect some devices and run speed tests. I presume I should expect the same speeds as my 5 ghz on the asus ?
